Hey guys,
I just got an ex500 and I'm trying to program in some of the FRS channels so that I can reconnect with family/friends after I get done with a job while ski patrolling.
Here's the problem i'm having:
FRS= cheesy walkie talkie
M=ex500
I can connect to the M using the FRS until the M tries to return a transmission. After that, the M will not recognize the FRS signal anymore. I can still transmit to the FRS from the M...I just can't receive signals on the M.
Settings on CPS are: Bandwidth 25kHz
Squelch type: CSQ for Tx and Rx
Options set: Tx power is high, Time out is 60 sec, Squelch setting is normal, Busy channel lockout is disabled
Signaling is Tx none rx none
Advanced: Compression type: disabled
Expansion type: Low level expansion
Emphasis Selection: De emphasis and pre emphasis
Reference frequencies are set to default for Tx and Rx.
Is there something I'm missing or forgetting to do? Any help would be greatly appreciated. Thanks!
Ben
M=ex500
Ben
