Running HP 2 next to RS pro 106--the freqs on Pro 106 are from RR--I am in Del Rio Tx area-I pick up trans on 106 that show 154.3700-P25:133 and from 154.3700 Wildcard 13996 that I cannot pick up on HP 2--Is this a programming prob or scanner issue?
Frequency 154.370 is one of the listed ones for the Del Rio site of this system: Greater Austin/Travis Regional Radio System (GATRRS) Trunking System, Austin, Texas - Scanner FrequenciesIn Val Verde County there is nothing in the DB
Val Verde County, Texas (TX) Scanner Frequencies and Radio Frequency Reference
At least not that I see. nIf you have something different - point to it in the BD.
Select ID Search "On"
I doubt it's a case of you "can't" receive these on the HP-2. It's much more likely that, using the main database, your location, and selective service types, the GATRRS traffic that you hear on the Pro-106 is not enabled in the HP-2. The stock antenna on the Pro-106 (which was made by GRE) is, in my opinion, a better one than the stock antenna for the HP-2, but not that much better.I'll give the favorite list search a try. Very disappointing that the 6 or 7 year old scanner picks up those transmissions and this HP 2 won't. I can receive some things from GATRRS but not these. Thanks for your help.
You can only set a trunked system to ID Search if scanning from a Favorites list.How do I search, not scan, with the HP 2?
The HP2 will receive them just fine. Every bit as well as the 6 or 7 year old radio. You just have to program the radio correctly. Your old radio will get more too if it is programmed as a system, and not just one frequency from a complete system.I'll give the favorite list search a try. Very disappointing that the 6 or 7 year old scanner picks up those transmissions and this HP 2 won't. I can receive some things from GATRRS but not these. Thanks for your help.
