progammer question
Hey there guys,
In progammer i am trying to figure how to program a specific frequency. It says that I can only program the transmit frequency. How do I find the transmit frequency as it is associated to the recieve frequency?
Any thoughs would be appreciated
Cheers
Ryan
blah546
The transmit frequency is 45mhz lower, so just subtract your receieve freq by 45mhz.
blah546
WCRadioGuy said:
If all you have is the RX freq, you should add 45, not subtract.
Ahh...
Entering a transmit freq of 806mhz in programmer will give you a receieve freq of 851mhz which is 45mhz higher then the transmit freq. So if you know the receieve freq then you need to subtract it by 45mhz to get the transmit freq...
WCRadioGuy
Salisbury, MD
blah546 said:
Ahh...
When entering frequencies in a radio, the actual frequencies are reversed. The repeater TX freq would be the RX in the radio and the RX freq of the repeater would be the TX in the radio. If you have a RX freq of 806, you would add 45 to get the TX freq of 851. If you were to subtract 45 from the RX of 806 you would come up with 761.
