Program a P25 channel without a Talkgroup in Armada
AG4BC
A local fire department converted to P25 and is not using a Talkgroup. I'm trying to program some new VM and VP radios for EMA with Armada, and it keeps adding a Talkgroup to the channel. Is it possible to remove the Talkgroup?
AG4BC
That's what I did initially, but cannot hear the traffic on the channel. If I press "Monitor", I can hear it. Could it be something else? The NAC is correct.
W3AXL
RF Engineer
Indiana
You can also enable "digital squelch" on the channel. This will unmute on any traffic regardless of TG/NAC.
otobmark
NC
I found I could use Talk Group FFFF with my VP8000 and the radio would unmute on any talk group. Also when TX FFFF any receiving radio will unmute regardless of its TG.
As far as my limited testing has gone, I don’t think any radio actually TX no TG. When I have no TG set on NX5000 or APX the receiving radio indicates it is receiving TG 1. Are you truly certain they have not set a TG? FFFF will solve the problem if you cannot find TG used. My guess is your real problem is an incorrect receive NAC (or split NAC). F7E on receive will open on any NAC. Digital squelch is a blunt instrument. Make sure you have two way communication with fire dept radios when you finish.
n3obl
O AES-1024
PA
Maybe confirm what they are using with whomever maintain their system. If you have an authorized need they should provide the proper information necessary
ie do not use radio reference to program official radios!!
WB5UOM
Radio ID comes to mind....
Not sure what version f/w the change happened in with the Vikings, but if no ID is used then audio wont open up.
The NX's went that way too for a while, but they changed it back thankfully
Project25_MASTR
Millennial Graying OBT Guy
Texas
No talkgroup means the P25 default talk group which is 1.
For most conventional applications it is very rare that a talkgroup is defined as the default of 1 has the most in common with analog (sub PL/DPL for NAC and you are done). If the newer Viking radios don't default to having an ID of 1 in the SUID location then you will need to set the ID to at least 1 as that may cause some issues on RX and certainly will prevent the radio from transmitting.
