Program Baofeng UV-5R to ignore CTCSS tones?
maxlockett619
Does anyone know if it is possible to program a UV-5R to ignore all CTCSS tones and receive any signals on that frequency? If so, how would it be done?
N4GIX
Hot Springs, AR
Using CHIRP, simply enter NONE in the Tone Mode column!
nd5y
Wichita Falls, TX
If you don't have Chirp then make sure Menu 10 R-DCS and Menu 11 R-CTCS are both set to OFF for each memory channel.
You can't change those menus after you program a memory channel, you would have to delete the channel and start over.
