ARC500: Program P25 Conventional w/ No NAC
tvengr
Well Known Member
Baltimore County, MD
How should a conventional P25 frequency be programmed in ARC500 when no NAC is given? SQ Mode P25 and SQ Code blank? Thanks!
tvengr
Well Known Member
Should I set SQ Mode to Search or None and leave SQ Code blank? I noticed that if I upload a file to a scanner with SQ Mode set to P25 and SQ Code left blank, NAC changes to 000 when I download to Win500 to convert a file. 000 is a valid NAC.
N4KVL
ÆS 1024
South FL
For those that are not aware, $F7E is the P25 equivalent of CSQ.
Some scanners follow the TIA P25 spec and this works, some do not.
