program pager with ctcss?
miked9372
how would i program a minitor with a ctcss code? example my freq is 154.31000 with a ctcss tone of 136.5 pl would i put that ctcss in the tone or are minitors not capable of ctcss and i have to do to a different brand i just want to monitor the freq without alerts
firefive76
Kansas
Minitors cannot be programmed with CTCSS (PL) tones. Just enter the frequency in your pager and you will hear anything on that channel as long as your function switch is programmed correctly.
N1GTL
CT
As Firefive said, just put the freq in, set to monitor mode and leave the tones blank. It will pick up anything on the freq. If you MUST have CTCSS, Unication pagers can do it but there are a lot of systems that strip the PL when paging. If that is the case, you can't use CTCSS.
