programing help
tony86s
im a newbie and just got this toy
(BearTracker Warning System with 800 MHz TrunkTracker III )
i was wondering if i am able to program that into my unit
Mowat 41MOWT (Toronto) 141.30000 141.43500 142.11000 142.68000* 142.90500* 143.34000 143.64000 152.00000
if someone could help me on that please and thank you
Dubbin
Findlay Ohio
You will need to be a little be more clear as to which scanner you have. Whats the model number?
Hammond, IN
If it's the BCT8, throw that thing as far from you as you can. I've had mine for 4 days now and still can't figure out the trunking side of it. I'm so frustrated with it all I want to do is pull my hair out :eek: :D (and throw it (the scanner, not my hair) out the window)
SSSG
tony86s
do you know how to program 141.30000 141.43500 142.11000 142.68000* 142.90500* 143.34000 143.64000 152.00000 that on the scanner
Dubbin
Findlay Ohio
SouthSideScannerGuy said:
Then see the post right above yours
:D :)
Thats not the answer...
Tony, I'm sure someone will step up and help you out, many people on this forum has the same radio.
Hammond, IN
You're right, it's probably not the answer he was looking for. I was trying to be funny, but I guess that fell pretty flat.
I was just venting is all.
At least I'm not the only one out here with issues with the BCT8. The thing truly is a pain in the butt to figure out.
Hopefully Tony will have better luck that I have had.
SSSG
