thhmike03
Hi. I am new to the whole programing world. I bought a Motorola xts3000. I also bought the astro saber & xts 3000 CPS software version R05.03.00. I am using the original motorola programing cables for the xts3000 with a RIB box. I have the serial port plugged into a serial to usb adapter. The firmware for the adapter has been downloaded. I went to read device the only options i have is com 6, 7, 8, or 9. When i select the com it tells me "communication with radio failed." My laptop has windows 8.1. If anyone can help me please let me know
Nasby
Ohio
Skypilot is right. You need Windows XP.
Also, a computer with a real serial port (not a USB adapter) will help too.
Project25_MASTR
Millennial Graying OBT Guy
Texas
You don't need Windows XP.
As long as you are using a later revision of Astro programming CPS you can use Windows 98, Windows 2000, Windows XP, Windows Vista or Windows 7 as long as they are 32 bit operating systems. A real com port helps but what helps even more is telling you USB adapter to be Com 1-4.
N4GIX
Hot Springs, AR
You can use the Control Panel/Device Manager/Properties/Advanced menu to reassign your USB "Com Port" to be 1, 2, 3 or 4 as needed.
thhmike03
Update
Ok I have an update. I bought a version of windows XP. I have installed it with no issues. Now every time I open the application it says the system cannot find the file specified. Does anyone have any ideas for help
marcotor
I ♥ÆS Ø
Sunny SoCal
Which serial to usb adapter are you using? Some of those can be wonky, and for many of them if they have Prolific chipsets, the 3.2.0.0 driver appears to work better than the newer versions (depending on the chipset, of course!).
thhmike03
I am using Manhattan serial to usb adapter. The new issue is that when I use the software on windows xp, it tells me files cannot be specified.
Project25_MASTR
Texas
You need a windows XP machine with a true serial port. No adapter. Some USB/serial adapters work, most do not.
Quality adapters if the need for an adapter is present. Tripp-Lite makes a good one…works with Astro on 32 bit windows 7.
