Programing TK-272G with KPG-56D
FVFD23
Frankfort, Maine
I am trying to program a TK-272G with the KPG-56D software version 4.22. It finds the com port fine. When I go to read the radio I get the message "Please check all connection and communication port settings". I have checked all the connections and use the same cable to program the TK-2312. I am able to program the TK-2312 with the KPG-134D software and the TK-7360 with the KPG-135D software with no issues on the same computer. Not sure if there is something different I need to do to program the TK-272G. Any help would be appreciated. Thanks.
KD2DXF
Nobody
Anytown, USA
I have found many times that if you hold the handheld with your hand, so you're able to push and hold the connector tight, while it reads and writes, it will work. Most likely a loose connection between the radio connector and cable. just hold it tight while your reading or writing and it should work. Please report back your findings.
DJ11DLN
Mudhole, IN
I have encountered the same thing on these radios. Be sure and hold it until the full read/write cycle is complete, they can I believe be bricked if connectivity is lost during the cycle.
