Programmer Version??
Tulsa
When I retired a few years ago Programmer 8 (on 5 floppies) was current; I was wondering what is the current version. Second, I use Programmer to program my VHF MRK and Orion coventional, would there be any advantages to move up to a newer version?
rmiles
Bel Air, MD
Current ProGrammer version is R20, and there's a newer software titled Radio Program Manager (RPM) which is up to version R2. Search this board and you'll find more info on it. Also see this link;
http://www.macom-wireless.com/products/p25/datasheets/ECR-7522.pdf
At the bottom of the second page, there is a list of which radios the two versions will program.
The attached file is the ProGrammer R18B02 readme file. It lists all the "fixes" between the different versions.
Tulsa
Thanks, I didn't read anything I would benefit from going to a later version. I guess I'll continue to program in ver.8
