USA
Greetings to all…
I have been reading posts on your site from time to time. Great site paid my dues. I am currently working on a project with Jaguar portables 700p’s P7100IP’s, mobiles m7100’s to start out. I have the latest version of Radio Personality Manger, and ProGrammer Software, using the TQ3370.
I am looking for fellow programs, who like to think outside the box. I need to be able to dump the data from the CMOS in its raw form from each radio. This information will then be stored in a database I am creating. I can access some of the data using different methods but not all. I have over 10,000 portables to inventory on this project alone. It takes too long to save the personality profiles, feature keys, and other info using Programmer.
For those who can help, you will be rewarded.
Forts
Ontario, Canada
10,000 radios? Oh my. Sounds like you have your work cut out for you. I'm not sure how you could streamline that process without some pretty fancy custom software. Hopefully someone will be able to brainstorm with you.
WCRadioGuy
Salisbury, MD
I know if you go to Tools-->Options and Directory Settings and check the box for Enable file backup, this will automatically save the tracking and feature data for each radio read or written to. The file is saved as the units ESN.trk and .enc. As for saving other radio data such as the personality, the only way that I am aware of is to save the personality.
Texas
It might be worth asking TAC about the command-line options to the programming software, so that you can set up automated batch files to do this. There are other tools also that they have that might work for you.
Some folks have built a programming station for portables using a Deluxe Charger (having modified the sense resistor to 0 ohms first) so that you can just put the radio into program mode with the "three finger shuffle" the clamp it into the charger and work on it without having to screw the lead on and off every time.
