Programmin Pro 96 PL Tone
emt_531
Is there a way to automatically program a pl tone to prevent bleed over from another agency? I tried doing a CT Search but nothing game up.......Any help would be greatly appreciated....
Macomb, Michigan
The use of PL can also help by keeping your speaker squelched when there is interference, as nothing in nature generates pl tones naturally. It won't reduce the interference, but just keep your receiver squelched until there is a transmission with the pl you programmed.
Note that pl is anything but "private" - that is a misnomer as all anyone has to do to monitor any frequency with pl is to just turn off the pl, or use a scanner that doesn't have it in the first place.
As for the Pro 96 I am not sure.
http://support.radioshack.com/support_electronics/doc71/71778.pdf
pgs 42-50 etc..,
emt_531
What is the difference between a PL Tone and a NAC code? I am trying to program the tones on P25 Digital frequencies, not conventional ones....
