Programming a Capacity Plus system
mfn002
Bryan, Texas
How do you program a Capacity Plus system into an XPR 5550 or 7550? I managed to get the TGIDs set up, but I can’t seem to figure out how to get the site frequencies entered in.
jtech48
OVB
The site frequencies must be added in the Channel Pool as Capacity Plus Voice Channels (right-click to add new). In the zone where your Cap+ channels will be, you add a new Capacity Plus Personality or personalities based on how many groups you will have (limited to 16 on an XPR6550, dont know about 5550 or 7550), then just add in all the group or private ID's, RX group lists (if any) and plug them in.
Now that's a very condensed version, I am only assuming that was the steps you were having trouble with. This video is very informative and helped me get started with Cap+ https://youtu.be/OveMxxEilfQ
mfn002
Bryan, Texas
Thanks. That's exactly the answer I needed. Now I just have to wait until tomorrow to see if it actually works.
CanesFan95
Was Homeboys-Scanna
Banned
FL
After you enter the RF frequencies into the Channel Pool, you have to create a Voice List: Capacity Plus > Voice > right-click > Add > Capacity Plus Voice List. Move the RF frequencies from the Available column to the Members column, and make sure they're the right LCNs (the numbers under the title "IDs" are actually the LCN numbers).
The talk group IDs are called "Contacts" (or sometimes digital contacts). Go to Contacts > Capacity Plus > right-click > Add > Group Call. Enter the talk group ID number(s) you want. Now add a new Zone, then right click on the Zone name > Add > Capacity Plus Personality. Fill in all the drop-downs and make sure you choose the Voice List and one of contacts that you just created.
CanesFan95
Was Homeboys-Scanna
Banned
FL
If you want RX-only, check the RX Only box, but then you need a way to tell it what talk group to RX on. So create a Group RX list with only 1 talk group ID in it: RX Group Lists > Capacity Plus > right-click > Add > RX Group List. Move one of the available TGs to the Members column.
Back to the Zone channel under the RX side, from the Group List drop-down, choose the group list you just created.
CanesFan95
Was Homeboys-Scanna
Banned
FL
And I believe the XPR 7550 allows up to 160 channels per zone, but the Scan Lists, RX Group Lists, and Flexible RX List allow allow only 16.
