Programming a Kenwood 272 G
mike3809
Paragould, AR
I know this is off the subject but i am programming a kenwood 272 g with the kpd 56 d software. On a repeater channel i cant hear anything but on a simplex channel i can, ive programmed other radios the same way but this one wont allow me to hear unless i hit the monitor button. What am i doing wrong ??
ramal121
Sonoma, CA
Double check the QT decode, make sure it matches. Otherwise you may have optional signaling enabled. Another oops is to set channel as "data", is this available on a portable?
