Programming a Kenwood TK 840 UHF
cwr111
Can someone tell me how to program a frequency in with 6.25 step.
I want to program in the UHF FDNY FREQUENCIES.
Someone had programmed it in my radio before but its hard for me to get in touch with that person. Any help woud be greatly appreciated.
Thank you
You will need a copy of KPG-47D, which is DOS programming software for that radio.
You will also need a KPG-46 programming cable.
You'll need a computer that will boot into DOS mode and has an RS-232 port.
a417
I've successfully programmed that radio series from DosBOX and from a CMD window, they're a little more forgiving then Moto radios and their requirements.
cwr111
Will I definitely be able to program them in...here is 1 of the frequencies 482.01875 .... How do I get the last digit in [5]
cwr111
I have it somehow in my radio someone did for me last year and it went in somehow can't figure out how he did it
I've never programmed one of those, so maybe there is a way to do it. If you can set the channel to narrow deviation. See if there is something that mentions "splinter" channels.
Maybe someone who's had some experience programming that model can jump in and help out.
cwr111
Thank you for all your help.... Anyone else know can help
ramal121
Lots and lots of watts
Calif Whine Country
The 840 will not program the 6.25 KHz step channels. The address lines to the PLL do not have the horsepower to support all the channel combinations that are in use these days.
Maybe you were thinking of the 12.5 KHz step channels like XXX.3875, .4125, .4375 etc. The radio will do these.
If just for receive only try to program as close as you can get and see how it sounds.
