Programming a Vertex/Standard brand LTR UHF radio
Costanza
RI - MASS
Hello all. Newbie here.
Quick question.
Can someone provide a quick lesson on the LTR, or if already done on these boards, provide a link to info?
Was not aware of any LTR systems in RI but it now seems as though I found one. Anyone know how many there might be?
Not too knowledgable about the LTR radio system, however I have a Standard GX4800UT mobile 2-way that I want to program for a friend to use for work. He has 2-way in his work vehicle. He wants to use my radio for a base.
What do I need for programming info to get this to work?
He has permission from his boss to use this on the freqs the business uses but reading the boards on LTR, I am a little confused. No...a lot confused, on what needs to be done. That is if I/we can get the programming correct. Do we need to contact the system operator for info? I do have the software to do the programming.
How do I get all the freqs I need?
Is there a way to use my pro2067 to do any of the decoding for the info I need? I do get a 6 digit number if I put in the 1 freq I do have and put the scanner on LTR
Could there be only 1 freq or does there need to be a certain number to LTR correctly?
Thanks in advance for any info/help.
Cos.
KC5MAI
Midland, Texas
You will need to get with the system operator. He will probably want to program the radio himself and he will also want to collect his monthly fee for having the radio on his system.
grem467
Houston, TX
first the techical aspects, with LTR you have to have the LCN as well as the talkgroups correct
now the legal aspects, you need to get with your communications provider, so that they authorize the radio being on the system (as said above).. the boss might have said it was ok for him to have a radio, but the system operator (who collects money for the use of the system) may not like that.
if you have never programmed an LTR before, call the communications shop and have them do it.
KC5MAI
Midland, Texas
Yes Technically you will need to know the LCn, talk group, area bit, every frequency in the system, whether the data is inverted or not, etc, before you can program an LTR radio.
INDY72
Indianapolis, IN
Not to mention the software, cables, etc... As stated previously, it would be best to let your system's tech guys do the programming unless you are a fully qualified expert in the programming of this radio, and know all the important information pertinent to your system.
