Programming a VX 414
staub2110
Frederick,MD
I'm trying to reprogram a vx 414 i used years ago. It was already programmed when i got it then, but have moved and want to program to the new area. I want to use it more as a scanner and pager. I have the frequencies in and all that works fine. I can't seem to figure out how the 2 tone alerting works. I cant find any programming manuals or videos. Does any one here know of how to program it right?
staub2110
Frederick,MD
So I called vertex and they told me i couldn't alert with 2 tone, but I'm pretty sure know it did before. Is there a way to use the 5 tone decoder with using only 2 tones?
radiotweester
Oregon
you get 2 pairs and possibly 2 groups per channel (depends on you system)
CE64 under Signaling -> Signalling Type -> 2 tone
Signaling -> 2 tone table and enter your 1st and 2nd pairs
Signaling -> 2 tone pretty self explanatory
Auto Reset to 15-60 sec so you hear the dispatch.
Duty - off duty is for pager use.
Secondary pair to a COMMON set of tones Pair #1 you always want alert about
CTCSS/DCS Complement I'd leave disabled.
Signaling -> 2 tone systems p
On your frequency page go to Signaling type and hit spacebar until signal appears under No select the pair you want to decode so lets say start at pair #@ (as #1 will be your secondary) next channel #3 and #1 is your secondary and so on. If you just want 1 set of tones don't check secondary, if you want the radio to stay open and not return to tone decode until you change the channel or hit a rest button uncheck auto reset.
I realize this is a bit of spoon feeding, but when I was first learning about this it helped. regards
radiotweester
Oregon
I'm not able to edit it, but the last part should have read:
If you just want 1 set of tones select that pairing #2-#10, but don't check secondary, if you want the radio to stay open and not return to tone decode until you change the channel or hit a reset button uncheck auto reset.
On your frequency page go to Signaling type and hit spacebar until signal appears under No select the pair you want to decode so lets say start at pair #2 (as #1 will be your secondary) next channel #3 and #1 is your secondary and so on.
-Hopefully that makes a bit more sense.
