Anytone Programming Anytone D868UV portable
caerickson
Phoenix, Arizona
I purchased an Anytone D868UV portable. I have another D868UV that I have programed with the Anytone software. I tried to program the new portable and the software tries to read the radio and then shows wrong version.
How do I determine the correct version of the Anytone software to program thsi radio?
The radio Firmware is 2.0, Hardware 1.10, Data 1.00, Pic 1.00 and Language 1.00
W1MTW
Windham, Me.
I see your firmware version on the radio is Version 2.0. That is the original firmware for that radio. What is the version in your other 868? You can do the info page through settings like you did with this radio, or open the CPS, and up top, it should show what version it is. It sounds like you will need to do a firmware update on your radio. You need to match the firmware on your other radio & CPS.
