Programming BCD 396Xt
howard,sd
#1
Setting up a BCD 396XT for my son. I understand that SD is moto type II however P25 1. I am using freescan and downloading from RR. A few questions: 1. On the trucked system freescan auto fills in mot type II/P25, I assumed this was correct till I scrolled down and saw a line saying p25 standard(digital XT) or P25 one Freq channel trunk(digital XT) Which would do I use.
2.) Freescan auto fills in APCO Auto is this what I want or do I go man or DFLT.. I'm guessing auto since I don't know anything.
3.) Freescan also auto fills in different modulation from auto,fm,nfm. which do I use or again just let the program do it for me
4.) what is a good P25 wait time.
5.) i noticed something about system band plan that fills in by itself, do I need to worry about this.
Thank You and please tell me I'm just overthinking things.
kmi8dy
ARIZONA and MICHIGAN
#2
p25 wait time is 400ms as stated in manual. nothing to worry about system band plan. i have caught system type sometimes useing wrong type, always check and correct if need be on this one.
tyytor
Wyoming
#5
hi, you should be able to get the Madison tower fairly good with it as is or add a any scanner out side or mobile antenna with good results or Mitchell with a vhf yagi.
