Programming Cable for BR330T
LoveTenn
Bloxom, Virginia
My programming cable for the 330T will not work on my Toshiba or Acer serial cable hookup. Is there any
other usb cable or adapter I could use for this scanner. The input is 15 pin on the computers and the cable end is 9 pin. Can I purchase an adapter from somewhere?
Keith_W7KEW
California
Are you sure that what you are attempting to hooking up to is a serial port and not a VGA port? Usually VGA ports are blue on the computer and have female adaptors, while serial ports are male adaptors with no color.
If the laptops don't have a serial port then you will need to buy a USB to serial port adaptor.
ST-Bob
Worcester, MA, USA
You need a USB to serial adapter. Most laptops and even desktops these days no longer have serial ports.
