programming cable
scanner99
Los angeles
Will the radioshack USB Scanner Programming Cable work on my bcd996t or do i need to buy the uniden usb 1? Or is there another cable i could get at best buy or curcuit city or radioshack that would work just as well. Thanks Happy Holidays
scanner99
Los angeles
is there any other model cable that you know that works that i could pick up local so it does not need to be shipped?
UPMan
In Memoriam
Arlington, TX
Many "Generic" USB --> RS232 adapters work (and are available at RadioShack, Best Buy, Fry's, Circuit City...). These cables have the USB plug on one end, and a DB-9 connector on the other. You plug the cable you got with your scanner into the DB-9. When you plug in the adapter, (assuming the drivers install properly) the PC assigns a COM port to the cable.
mule1075
Washington Pennsylvania
thats how i do it works great for me.
