What type of cable is required for computer programming of the BCD325P2? Does it use a USB mini or the type that the BCT15X uses?
Thanks in advance.
Thanks in advance.
Mini USB.
You will need to install the driver for the cable to work: Driver Install for the Uniden Bearcat | Scanner Master
The owner's manual doesn't provide much information about using quick keys. Here is a PDF file which will be very helpful:Thanks for the link. I have a 325P2 on order and it should arrive tomorrow. I'm already putting together some programming via Freescan,
If you have any problems, you can attach your programming file(s) and we can check for errors.It's been a while since I've programmed a DMA scanner, via PC or manually, and I'm a little rusty at it
To clarify. The cable is just a plain vanilla mini USB cable, but the scanner, itself, will require the USB driver. It's a very easy setup.
Consider purchasing the ProScan programming software. It is a first rate product and well supported here on RR. Initial install give you a 30-day trial.
I know! Years ago, I wore out the scroll control on a BC296D selecting characters for alpha tags on a large system.Too much knob twisting manually LOL.
I barely have the patience to manually enter a conventional channel!So far, so good. I've done just a few systems so far, both trunked and conv, via PC and even gave a "small" trunked system a go manually. It worked, but PC programming is a must for any large systems. Too much knob twisting manually LOL.
