Programming CB Channel 19 in Pro-107
hornjt
Trinity, TX
I am trying to setup my Pro-107 to monitor CB Channel 19. I think I have seen while browsing the library the cb channels, but can not figure out how I got there. Any help will be appreciated.
nexus
Mississippi
Page #35 of the manual SERVICE SEARCH
step 1: PRESS MENU
step 2: SCROLL TO SEARCH THEN PRESS THE > ARROW KEY
step 3: SCROLL TO SERVICE SEARCH THEN PRESS THE > ARROW KEY
step 4: SCROLL TO CB AND THEN PRESS THE SEL KEY
You're now scanning all 40 Citizen Band channels.
If you want to program channel 19 in specifically you'll need to follow your manual on programming a frequency into a memory...
Channel 19 is 27.1850 MHz AM
KC5EIB
Flower Mound, TX
The way I would do it is:
to put the SD card in a computer
run the I-scan software
copy config from SD card
and enter the frequency under the "Conventional frequencies" or "Playlist" tab
copy config to SD card
Put SD card back in scanner
