programming cm300 pm 400
Meriden,Ct.
#1
Greetings,
Will either of the following work for both the cm300 and pm 400 radios:
commercial series customer programming software
ver. r05.15
professional radio CPS
r06.12.04
Dave
The trouble with coffee is that you only rent it!
