Programming CS-750 to scan Cap+/Con+
natedawg1604
Denver-Metro
#1
So I just got a CS-750 earlier today, and I can't figure out how to get it programmed properly (via CPS). I'm trying to build a codeplug for scanning a Cap+ system (RX only mode) with 2 freqs and 2 TG's, but I can't figure out how to make it scan right. For some reason the radio hangs on a single slot/frequency (I think), and it won't continue scanning after the first transmission ends.
Can someone possibly give me a basic step-by-step overview of how to configure this properly?
natedawg1604
Denver-Metro
#2
Well I *think* I may have figured it out. I just realized this radio scans digital channels at 1/3 of a second/per channel, so with a 2-freq Cap+ or Con+ system there is up to 1 1/3 second delay when a call moves between slots or frequencies. Does anyone have any tips on maximizing scan speed for Cap+/Con+ monitoring?
p.s. This is a damn cool radio, I love the audio quality and tactile feel.
#3
Programming CS-750 To Scan Cap+/Con+
I also just bought one of these. My local school district uses Moto TRBO Capacity Plus. I have the correct frequencies, color code, and Time Slot. Where do I enter the Talk Group Numbers?
Also, how do I select the Monitor Mode? My understanding is that will monitor all traffic on the system.
natedawg1604
Denver-Metro
#5
First, Monitor Mode has limited utility because it does not currently work in scan mode! Rather, monitor mode only works when you're parked on a single frequency associated with a single time slot.
Second, in CPS (assuming you bought the $5 programming cable?) you have to input talkgroups under DMR Services/Contact; you then create an RX Group List associated with particular talkgroups. Under each digital channel, you then select a particular RX Group List. Does that make sense?
