APX Programming help/ shortcuts? Supposedly I cant clone...
JMR3865
Monmouth County, NJ
Hi All,
I just received our radios back from the trunked system administrator. I'm to program the VHF side of our APX8000's. There is a system key so I cant change anything on the trunked side. I'm told that I have to program each radio individually and can't clone them. I thought cloning would of left the trunked system info in place. Is there any short cuts with the software that I can copy and past the new zones and new channels, new alias's and everything?
N1GTL
CT
Most fields can be exported to individual .xml files and then imported into other radios.
JMR3865
Monmouth County, NJ
I found that feature! As long as I don't export or important any TRS fields, it shouldn't change any of that, correct?
jthorpe
Get a new radio administrator. Just export the conventional personalities etc to an XML file then import them back per radio. You should be good to go.
