programming ht1250 issue
njffemt08
Was emtfirebug14
#1
hey yall i acquired software to reprogram my ht1250. when i try to read the radio it keeps telling me that there are no comms ports. i bought a brandnew cable and all drivers are installed. i believe software 6.12.09. any help is greatly appreciated.
buddrousa
NW Tenn
#2
1.Are you using a USB cable?
2.Are you using a 9 pin cable? Is it a ribless cable? If not do you have a motorola RIB?
3.Have you picked the correct com port in the software that is show in windows device manager?
4.If you have picked the correct com port have you set the com port to the settings listed in the Motorola Software?
njffemt08
Was emtfirebug14
#3
sorry forgot to put that i am using a usb cable and that what ever comm port i select it says the same thing. i have tried the cable in all 4 of my usb slots on my laptop
buddrousa
NW Tenn
#4
Look in Windows hardware manager under ports and see what comports ports are listed and choose one of those
SteveC0625
Northville, NY (Fulton County)
#5
Connect the cable to the computer. Then open up the Device Manager and Find the Ports (COM & LPT). Double click on that and select your USB cable.
Tell us EXACTLY what the name of the cable is.
Then double click on it and you'll get the Properties window. Click on the driver tab. It would be best if you could post screen shot of the window display, but if you can't please tell us the Driver Provider and the Driver Version.
This may well be a small problem in your computer and have nothing to do with the radio or the CPS. Let's sort this out first.
It would also be more than a little helpful to know what version of Windows you are running.
njffemt08
Was emtfirebug14
#6
i will try going through my device manager tonight when i get home from work. i am running windows 7. i am using the same computer to program a kenwood 2180 and i have no issues reading that cable
Zsneese
Martin, Georgia
#7
Are you running the windows software in the classic theme? When I ran it, it gave me the same error and I changed the windows theme to classic and it worked fine then.
Those views reflected here by me do not reflect those of my department.
njffemt08
Was emtfirebug14
#8
I would assume so I just had the computer rebuilt by Microsoft and I havent touched any setting other then putting it into projector to extend my screen
SteveC0625
#9
While you are in the Device Manager, make a note of what Com Port is assigned to the cable.
Plug in the cable, do the Device Manager lookup and make note of which Com Port is assigned. Then, with the radio on connect the cable to the radio, then fire up the CPS. Do this next step exactly as I am giving it to you. Click on File and then click on Read Device in the drop down. When you do that, you'll get a little window asking you to select the Com Port. Select the same Com Port as the Device Manager indicated, and you should be able to read the radio.
If this doesn't solve the problem, we'll need to take a closer look at your USB cable and the driver. But let's do this first. Since you are running Win 7, you won't have the "latest driver" problem. Win 10 is too smart for its own good because it wants to find and assign the absolute latest driver for each device. More on that if you don't get it going with the above info.
SteveC0625
#11
could it be possible that i may also have to update my operating system as well
Highly unlikely. Almost every time someone has the "can't read the radio" or "computer doesn't see the cable" problems, the solution turns out to be pretty simple and straightforward. You are using the latest (and final) version of the Pro Series CPS, and you're using Win 7 which has very few problems with this CPS.
Just do what I asked first before you worry about anything else.
njffemt08
Was emtfirebug14
#12
ok i have gone through that process. it now registers the cable and what comm it is in. when i go to file then read radio it says "couldnt open port.check whether device/rib on or not, and the device to rib, and rib to pc connection are ok"
buddrousa
NW Tenn
#15
That would be the MOTOROLA SOFTWARE it also states port speeds like 9600 8 none and 1 those have to match also. What version Motorola CPS are you using?
SteveC0625
#16
do you mean when i go to read radio selecting the port that the cable is plugged into
Go back and re-read my directions in Post #9. It tells you when to select the port as you go to read the radio.
He said in his original post that he is using R06.12.09. In Post #11, I clearly stated that he was using the latest version of the Pro Series CPS which has very few problems running on Win 7.
There should be no need to adjust port speed, etc. It works fine with default settings.
SteveC0625
#18
Steve I just remember my old days programming
I understand that, but this series of radios uses a CPS that was written for windows, and updated at version R06.12.05 specifically for Win 7 64 bit. Windows software rarely needs fine tuning of the ports like the DOS based programs did. Been there, done that.
All the OP should have to do is make sure the proper Com Port for his cable is properly assigned in the software. I gave him clear directions on how to do that.
