Programming Icom IC-F3022S
XYZ86
Hi,
I am having problems programming my IC-F3022S.
When i try to "clone read" i get the error message "no response from transceiver", but when i click "I/O Check" or "Clone info" i get data from the radio, so i think the communication should be ok.
I am using a OPC-478UC cable and the CS-F3020 rev.3.4 software.
Any help is much appreciated!
Blackpointcorp
GARDNERVILLE
You need to check your firmware
Make sure you have the right CPS for the firmware
Also if you are using a computer with windows 8 or 10 check your OPC-478uc and see if it has a small B marked on the sticker. If this is the case then you need to update the driver from v1.0F/v1.3 to v1.4/v1.5. Hope this helps
Frederific
Many Icom models let you Inhibit reading data from the radio to software, to prevent a lost radio being read by a nefarious 3rd party - is it possible this is set on your radio? That's very common cause of this behaviour. You may be able to write to the radio but not read from it.
It's a setting in the ICF - from memory I think it's in Common/Common.
XYZ86
Yes, I think this might be the problem.
So I guess I have to program it from scratch then [emoji17]
Sent fra min SM-G960F via Tapatalk
