Programming Mil/Air freqs in the 800
1Dave
How complicated is it to program Mil/Air freqs into this unit????????
kg4ojj
Sumter County, GA, USA
No harder than any other conventional frequency. If you setup the source data correctly, you can copy and paste from an existing spreadsheet, etc.
Enter frequency such as 357.000; choose AM mode; don't search for tone (PL/NAC); choose analog mode.
Load it into the -800 and scan. The stock antenna leaves a little bit to be desired for milair, as it was designed for general receive on all bands.
BeerNutz
Knoxville, TN
Do you have the freqs? Or, do you want the EZ Scan software to find them? If you want the software to find them, what state?
