Programming my TH-F6A to rx local police/fire
PCTEK
Northern California, USA
I just received my Kenwood TH-R6A. The salesman at HRO assured be that I could program the "B" side to rx local police & fire frequencies. (I am in Northern California). When I try to enter 488.3125, the radio only has enough blank spaces for 488.312. The minute I press the "2" the radio changes it to 488.300. I haven't had much luck using the KRS-F6 software to do the same. Is this radio not capable of doing this?
pctek
KK6FPE
AK9R
Staff member
Super Moderator
Central Indiana
Change the frequency step size to 12.5 kHz. Tap the F key then the 0 key.
PCTEK
Ok
Yes, I was able to get to the desired freq. 488.3125 using the tuning knob by changing the step increment. I've read the manual, and I can't figure out how to assign what is now displayed and receiving to memory channel 51 so that I can download from the radio to the software so I can see how it is configured and then I can setup the other public safety freq. I also can't seem to assign the CTCSS tone, 114.8 to the frequency. When I switch back to the 2m display, I can set a CTCSS tone there (A side). Sorry for the rookie questions.
jhooten
Paige, Republic of Texas
From an owner of a TH-F6, They are a very good amateur radio. However as a scanner they suck. Nuisance lock out, for example, requires menu navigation. Love mine, won't give it up, but I have a scanner also.
PCTEK
scanner
I did notice that with the F6A in the upper 488 freqs. I to have a scanner, many actually, but my portable scanner is the Uniden 396XT but I hate to carry two radio when one can do both. But I probably will end up doing that since the audio level of the 488.x frequencies is pretty low.
