Programming Off-Set Frequencies in Motorola CPS
nokones
Sun City West, AZ
In the CPS, you go to the "View" menu, click on "Options", then go to the "Frequency Options" page. Check the box for the "Zone Channel Assignment Page" to enable the frequency off-set to be entered after you enter the receive frequency. For the high frequency to be the off-set for transmitting you enter the numbered value of the off-set you want in the off-set (MHz) box and if you want a transmitting off-set that is the low frequency of the pair, you enter a minus numbered value i.e. -5 in the box. In order for this feature to work correctly, you have to enter the receive frequency first.
Also, there is the "Channel Picklist" Feature. This will paste a channel from a saved picklist so you don't have to keep on re-entering the same channel data a gazillion times, you just pick it on the channel line and it will populate the data for you. It does save keystrokes. Let me know if you need any help with that feature
This setting will be global for all channel entries in the Zone Channel Assignment Page. To disable it just unckeck the box.
