Programming p7100
greenthumb
Colorado DB Administrator
#3
Yes, there are two software programs you can use depending on the version of radio code. Older code will use Harris ProGrammer, and newer radio code will require Harris Radio Personality Manager (RPM). Both of these programs can be obtained from Harris and will be costly as compared to software typically used in the scanning hobby. You will also need a programming cable to connect the radio to a computer which can be obtained through a variety of sources besides Harris.
