Programming PRO-164
OntFF221
Ontario, CANADA
Afternoon, All
I'm having an issue trying to program my PRO-164 for Fleetnet (as well as conventional freqs)
The scanner keeps changing the freq's I program - for instance - MOH Paging - I enter 149.440 (either thru Win97 or manually) - the scanner "corrects" it to 149.4375... Or, for fleetnet, to enter the trunking info - I enter the base freq of 141.0150... Scanner "corrects" it to 141.0125
Is there a setting I'm missing somewhere, on step size or ???
HELP!!!
OntFF221
mciupa
DB Administrator
Moderator
I believe the scanner is "correcting" the values that you are entering to American step size of 12.5 KHz increments.
Check your firmware version and see if any ammendments were made in later firmware releases to accomodate Canadian values.
OntFF221
Ontario, CANADA
Scanner is currently flashed to 1.06, which is (according to RS's website) the latest and greatest; although their is rumblings that the OEM is about to release 1.07, and that RS's version should be fairly quick behind...
I'm not seeing anything about step-size in the firmware notes. I'm going to throw this question over into the RS forum as well...
Laz
