Retevis programming rt22
Dave520
Connecticut
I just bought a couple of those and was able to use Chirp to program some FRS into them. I could not get the Retevis software to work. There is a selection when you hook up the radio for the RT22. Read the radio first and save the default programing in case you need to go back. I believe you can import from RR directly from the menu at the top.
Sorry I do not have it in front of me right now. You will want to spend some time learning how to use Chirp as that will make things easier for you.
Good Luck,
Dave
