Programming scan on the fly?
beaker7
Boise, ID
I have a Motorola XTS 5000 and sorta figured out how to make a scan list in the CPS but would like to be able to set up a scan list on the fly like this https://youtu.be/M2AHqxKtsfo?t=2m31s I have the program button programmed in but when I go into program scan list it wont deselect or select channels to scan. help would be greatly appreciated!
n8dhw
Middletown, Ohio
Did you set up your Scan List in the CPS for Operator Selectable Scan? If I remember correctly you have to specify that in every Scan List you create if you want to be able to modify them from the keypad.
beaker7
Boise, ID
Ok, did a little more digging and found it. Thanks for the help!!!
n8dhw
Middletown, Ohio
No problem glad to help just hadn't messed around with an XTS codeplug in a long time to remember where the setting exactly was.
Sent from my iPad using Tapatalk
