New SD-Card
Under the Scanner tab select clear user data. When the box opens check Display all Drives, then refresh. Select the drive letter.
Now update firmware, a box will open and select the correct model
Update the master database
Go to Edit profile and turn on or off the favorite lists you want to copy and monitor, also a good time to set the service types
Write to scanner
When the scanner sees the new card it will automatically update the firmware, either when you unplug the cable to the scanner or when you insert the new card if it was created on the PC.
