Programming the HYT 610P
radioman1044
Garden Valley Idaho
I have a new Model TC-610P U(2) UHF radio 450-470 MHz
Software -- HT610PE Version 1.04.06.
My first task will need to be retrieve all information from my existing radio which is the same model as the recently purchased one.
when trying the read from radio to pc a pop up window says to upgrade to a newer software and will not continue.
To my knowledge I have the latest software for this model of radio.
Any suggestions would be of great help.
Regards,
gregg22
monroe,mich
do you have the latest driver for the programing cable? what kind of computer are you using?without the latest driver
you can't use any computer newer that win 7 32 bit
gregg
radioman1044
Garden Valley Idaho
PC is a new (6 months ago) Dell latitude E5530 64- bit Operation System Windows 7.
Programing cable is new, purchased last week and installed with the driver CD that came with it.
Thank You
Larry
Drachen_Fire
Center Township, PA
I'd also say to take a look at the cable drivers. You will want to check out Prolific's website, and grab the driver for the USB/Serial converter, running 64 bit W7. I believe the release that shipped with HYT's cables are all 32 bit.
radioman1044
Garden Valley Idaho
Thank you for your suggestions and here is a update of what I have done.
a) I have loaded the programming software and USB cable onto a older windows 32 bit Vista pc and still are seeing the same results.
b) As suggested I re-loaded the latest’s driver from the prolific website. Still receive the same results.
c) This morning I loaded both the USB cable and software onto a 3rd older windows 32 bit system running Vista. Resulting with the same popup window.
Select Read from Radio
Click ok----- than this pop up accrues (upgrade to newer software)
Open for any suggestions.
Larry
