Programming with the Uniden GPS Cable?
High Bridge, NJ
#1
I am missing my programming cable but I have a gps cable I bought. Does anyone know if you can use the GPS cable to program the scanner using a null modem adapter, (essentially the opposite of using a null modem adapter to use the programming cable for GPS use).
PA
#2
What scanner? The GPS port is for GPS use only, not for programming, on most Uniden models.
dave3825
New York
#4
I can tell you that the data cable from a br330t will work as a gps cable on a Bcd436Hp using a null modem adapter ..
ProScan
Ontario, Calif.
#9
That's incorrect. All Uniden scanners with a GPS port doubles as a RS-232 Serial Port.
I stand by my statement. I never said "programming" I just wanted to correct what jonwienke said which I think is wrong "The GPS port is for GPS use only"
UPMan
Uniden Representative
Arlington, TX
#10
Correct, the GPS port is a standard serial port that can be used for PC control and sometimes other things.
garys
Eastern MA
#11
I was going to post a question on this topic, and I'm glad someone else brought it up. I have a 436HP and I'd like to get data out of it to feed a display program. Will the 435Hp feed the RH-536 program? I thought I had it working some time ago, but when I've tried lately, I get an error and the program crashes. I can't get it to work using either the GPS/serial cable or the Mini USB port.
I can feed Scanner Monitor with the from the Mini USB court, but not the GpS/serial port.
Is it possible to use the GPS/serial port to get data out or did I imagine that I did that?
