Programming
johearn
Hello,
I am fairly new to the whole scanner scene and I am having some problems programming my Uniden BCT15X. I would like to my local police agency in and they use the Motorola Type II Smartzone so I'm assuming it's 800 mghz but all the system frequencies given are in the 400 mghz range so I am wondering how I program it in.
johearn
So what should I do differently in regards to programming the system in?
Thanks for your help!
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
The system type has only a little to do with the freqs it uses. It would help if we knew precisely which system you are trying to program. Go up to the very top and right underneath the site title there's a pulldown called 'DATABASES'. Select FREQUENCY DATABASES then use the map and supplied pulldowns to get to your state and county.
We can be a lot more specific with help if we know this. And just to get you started. we have an extensive wiki article (links are always blue, by the way) on how to program DMA related scanners here...;
Program your DMA Scanner - The RadioReference Wiki
Note that at the bottom, there are links for the Easier to Read manuals. I would start there
Mike
