Progress energy I need to frequencies
KE4ZNR
KE4ZNR@radioreference.com
Hey Jake! Hope all is well :)
As has been discussed in the past Progress Energy uses
an Opensky system which can not be monitored by commercially
available scanners. So you are not going to be able to monitor them.
Sorry!
Marshall KE4ZNR
ts548
Will not be able to monitor it. It's Opensky which is a 4 slot TDMA system and there are no scanners that will work with it.
KM4WLV
Rockwell (Rowan County), NC
Progress Energy is moving over slowly but surely going to Open Sky, which we all know is what Duke Energy is using now. It may be a while before anyone sees the change over to Open Sky in an area where Progress provided service as the primary utility company. They will continue to use their old Motorola system(s) until Duke can get the Open Sky system expanded to those areas.
Beside Duke/Progress Energy, other companies that contract for Duke and need radios to communicate with Dispatch in Charlotte at the Little Rock Operations center include Pike, Utility, Williams, etc.
Duke is moving fairly fast to consolidate everything into Open Sky but there isn't an exact time frame. Hope this helps out !!
wtp
Port Charlotte FL
in my opinion
i personally like the uniden 396xt
uniden has new radios coming out soon (next year)
there are some threads on radio reference about them.
KE4ZNR
any updates to the opensky transfer? also i got 33008 and 33808 if anyone could label these 2 thx
Cmon now brother...you know better than to bump an old thread.
Create a new one as this one is getting locked.
Thanks!
Marshall KE4ZNR
