Some thing that I consider shortcomings in each part of the scanner, the Hardware, the Software, and the Database.
Hardware -
- audio too quiet for window down driving.
- No scan button to force scanning from an unwanted conversation.
- too tippy without the base
- base does not lock on like a mount.
- cannot have multiple search ranges running, have to reprogram each one
- Extreme features for trunking don't all run at the same time
Software -
- does not allow for remote locating of radio w/ full control
Database (since the database is such an important part it must be considered)
- too many duplicates (one county system loaded the same frequency 26 times)
- many coverage circles are overly optimistic (25 miles for UHF fireground?) resulting in scanning channels many miles out of range.
chris
How did they try too hard, they did a great job on the HP for the target customer and then made it better for advanced users too. Show me any other scanner that can do all the HP does! Also show me one with the advanced capabilities it has and that do it all at once....
Audio - mount it PROPERLY and you can hear it fine even with the windows down and 3 girls 7 to 11 screaming at each other....
Scan button? simply double tap the channel/department or system and it moves on....no need for a scan button.
To tippy without base- there are lots of mounts that work too....
Base doesn't lock like a mount - see above comment
Canot have multiple search ranges - sure, just make up search ranges using FL.... it aint rocket science...
does not allow for remote locating of radio w/ full control- what, do you need a remote control? Lazy people....
- too many duplicates (one county system loaded the same frequency 26 times)- Do they all have the same PL Tone or no tone? If they have seperate tones then there is a REASON they are in the DB 26 times.... again not rocket science. However if they are all the same then the DB admin needs to clean it up and use it once.
- many coverage circles are overly optimistic (25 miles for UHF fireground?) resulting in scanning channels many miles out of range - Really? How is their boundary OPTOMISTIC since they are set up for the jurisdiction they cover. Also there are other considerations, YOU may not hear them but someone else with a better antenna might. I regularly hear UHF fireground ops on my HP from much farther than 25 miles. On some systems 40 miles isn't out of the question. So what might not work for you might for others.
