ProScan Monitor Client Android?
saboken
Canton PA
Is there a way to monitor with proscan with a Android device? I have the proscan software installed and running the software sees my BCD536hp and I have the IP setup to record over IP that part is working but I haven't been able to find a Android app to monitor the scanner remotely? Before I pay for the software I want to see if it's worth it for what I want, ultimately I would like to control the scanner remotely but simply getting access to what's being heard by the PC would be good enough and possibly the recordings proscan is storing on my PC when I'm away from home. Thanks
saboken
Canton PA
What about IOS? I have a 2017 Ipad
Sent from my Pixel 3 XL using Tapatalk
GTR8000
NY/NJ Database Guy
BEE00
eaf1956
Evansville, IN
Use the web server in Proscan and you can use any web device. Android, IOS, computer whaterver can access the web.
Whiskey3JMC
Another Pesky Scanist
Simulcastylvania, TE
Web Server is one of the best features Proscan has to offer. View and control your radios via any web browser, Android browsers included. Listen to the audio output via your favorite streaming app of choice, I prefer VLC. If you record audio to your hard drive, you can even view & download folders & files to your phone
73422
mancow
N.E. Kansas
How do you mitigate delay with the web server? I'm seeing about a 10 second lag.
ProScan
Software Provider
Ontario, Calif.
The delay is caused by the media player latency/network buffer. See if the media player has an option to reduce the latency. If not then change the option on the web page "Delay & Metadata Delay" to 10 seconds so the data & audio appear in sync. BTW, This is on the proscan.org web site in the FAQ section.
mancow
N.E. Kansas
Thanks, I just ran across that but still trying to get my head around it and get it figured out. I was using the built in player at the top of the page.
