TailGator911
Silent Key/KF4ANC
I asked a question in another thread and either it got busy and overlooked or it was not seen, and I have had some time to revise my question into several. When I first got ProScan it was for my BCD536HP. Since then I have added an SDS100, BCT15X, BC125AT and an SDS200 to my desk. To add instances of ProScan for each scanner, I simply highlighted the main .exe file in the original folder and right-clicked 'Send To Desktop as Shortcut' and then renamed the shortcut the same as the designated scanner. Have all the icons lined up and ready to go. Everything working perfectly, all displays rock. Nary a single complaint.
1) I do not have individual folders with dll files for each scanner. Should I reinstall each instance and make sure they are in individual folders?
2) Is my install (or lack thereof) the reason why they all read 536hp on the title bars?
3) I take it this is the reason why my 536hp is the only scanner where that instance of ProScan logs at the bottom?
4) So I should disconnect everything. Delete the shortcuts I created for each scanner/ProScan instance. Make folders for each scanner and name them accordingly, then copy the .exe file and dll file from the original folder and paste them into each folder. Send the exe file of each folder to the desktop as a shortcut icon and rename them accordingly for each scanner. Initiate each of them and assign ports. Am I missing anything?
Thanks for the help!
JD
kf4anc
JD
kf4anc
