roccuschaser
Been checking out software to connect to my Uniden BDC996P2 scanner. I am kind of favoring Proscan.
When I setup Proscan through the setup process it connect from the computer to the scanner just fine. Question is when I start Proscan and the scanner is turned on shouldn't Proscan automatically connect to the scanner? When I start Proscan nothing happens the virtual display does not run. How do you get Proscan to run when you open it??
