So I've had this problem now for I don't know how long now, but too long. Whenever I close down the ProScan program many times, when I go to open up the next time, doesn't matter if I've shut down the computer or whatnot, when I open it back up, not all the windows will open up. The 3 open windows to open and connect are the History logging window, Favourites Editor window and the virtual scanner window.
So this quick fix does work. Which you edit in the config file. Copy this into the config file, save and restart program. Supposed to work right away. It has, but doesn't all the time.
[WINDOW STATE]=
[WINDOW BOUNDS]=
[WINDOW LOCATION 1]=
[WINDOW LOCATION 2]=
[WINDOW LOCATION 3]=
So that's all fine an such, however for whatever reason recently, every single time almost that I shut down, reboot, unplug usb, uninstall, reboot, reinstall etc....I have to do the fix. However, even that won't work right away. It will open as I want it, but only have saved it in that position, but I can't reconnect right away. I have to do this whole process multiple times before I can open it up and have it connect right away with all windows in the correct position. Why?
I know the quick fix edit works, but why not right away like it should. Why do I have to keep doing all this after having completely shut down, and restart fresh.
This last time, took me about a half hour before it actually worked upon opening it up and in position that it connected right away.
[WINDOW STATE]=
[WINDOW BOUNDS]=
