Thanks for the replies. To answer the questions first: 1. the CC is 99% or 5 bars signal strength on all VCs and CC. Programming by hand if that helps. The problem is one wildcard TGID on one TSYS in one scan list – the scan mode stops on CC activity but only displays and plays half the active VCs, the other VCs are silent and shows “ID Wildcard” - the scan mode waits to resume after their transmissions are complete.
2. Rebanding came to mind first but UCAN was the first to reband and this is not the first generation of rebanded scanners. Do I have to make an adjustment for all rebanded systems and what would it be? I have been through the book and all the menus. The only things related I can see is the multi site (tried all selections), T Tables, and fleet map selections (set to type II). It isn’t the first and last items. T Tables is not explained in the manual. What are they and how do they work?
Additional testing shows 3 frequencies 853.3375, 852.0875, 853.0625 are consistently shown and heard with CC activity while 4 frequencies 852.9500, 852.375, 851.975, 852.325 are consistently not displayed as a VC and not heard on PSR-310, but they are heard on the PSR-310 and PRO-95 as conventional repeaters using TUNE function. When activity is found on these 4 frequencies, the display shows “ID Wildcard” instead of the VC and the entire text of the display flickers. Also, once in a while the PSR-310 displays and plays 863.9375 where there is no signal, just noise. Sometimes the radio resumes from this and sometimes it doesn’t.
The next step is to program my PSR-400 to this TSYS and see how that radio performs.
All the frequencies listed above are included in the DB and I can hear on the PRO 95 the continued conversations and see both radios resume scan together.
