PSR-500 Discriminator Tap Clarification
highmaster2
Cropwell, Alabama
Have read most, if not all, the threads on accessing the disc tap in the PSR-500. What I haven't seen (probably missed) is whether or not any resistance and/or capacitance should be in series or parallel between the tap point and however you decide to get it out of the radio.
Any clarification would be most appreciated.
puzzleriddle
bham, Bama
unless I am mistaken neither was used in doing my PSR500 tap.. should work just fine. Just to add I confirmed the above with the Guy that did the tap
RonnieUSA
Rowan County,KY (Morehead)
highmaster2
Cropwell, Alabama
I did. As far as I can tell, the only mention of a resistor or capacitor was in reference to the discriminator tap mod for a Pro-106...
highmaster2
Cropwell, Alabama
PuzzleRiddle...
Thanks for the confirmation. Have been trying to monitor Pell City PD but have not been able to get anything but garbled audio using my AR8200. May try the PSR-500 to see if there's any difference.
