PSR-500 Original Design vs. Others
Which design do you like more?
  • PSR-500 Original Design
    Votes: 14 28.0%
  • PSR-500 Current Design
    Votes: 28 56.0%
  • RadioShack Pro-106
    Votes: 8 16.0%
  • Total voters
    50
BuiltonAsus
Looking back at the original thread that first introduced the PSR-500 I've noticed there are some design changes that have occurred, and some that seem to be on par with the upcoming RadioShack release. Looking at all three, I believe I like the original design and color.
Just checking to see what others think. Vote which one appeals to you more. Vote:
1. Original Design
2. Current GRE PSR-500 Design
3. Upcoming RadioShack PRO-106
wnjl
Tabernacle, NJ
The new Radio Shack one looks too...Radio Shack-ish, lol. Not that I have anything against RS scanners, they are what got me hooked into scanning. I think I'd actually go with the original design too.
abqscan
DataBase Administrator
Moderator
AOA
The PSR-500 was designed for RS. That's why the original design looks like the Pro-106. =)
GTO_04
I would prefer the speaker location of the current PSR-500, but with the black case like the one on the left.
GTO_04
texasemt13
CenTex DBA
Hunter, TX
I'm not a big fan of the lower speaker on the 106... The PSR-500 is appealling to me because of speaker location (I prefer the 2nd edition though), to me the first with all it's colors looks to "walkie-talkieish," if you will.
jeff0780
Hampton Roads
GTO_04
I agree. I think if the PSR-500 would have been black it would have looked better and I think the speaker looks funny on the bottom.
raisindot
Vote me for current design
Personally, I think the current design has the right balance of form and functionality. I don't like the idea of having the speaker on the bottom--it projects less, and could be potentially be affected by sound absorbing material you might put the scanner on (for example, if you put the scanner on a piece of felt or cloth).
The current designs gives the right amount of real estate to the buttons--the area seems more cramped on the other designs, and is much closer in appearance to a blackberry/cell phone format, which I like.
In terms of colors, the gray/metal case of the PSR500 doesn't bug me a bit. I keep the thing in a case anyway, so all I'm seeing is the display and buttons.
Suzie
N8IAA
Fortunately, GA
You didn't put (none of the above) on the poll. I truly think that GRE should have made a scanner the size of the 396. As much as I like both my 96 and 97, they need to be in smaller cases. When I go out, pocket sized scanners fit my lifestyle. I'm sure there are more out there that feel this way. GRE makes an outstanding product, but Uniden did it in a smaller package.
So, if you didn't get my vote: it is none of the above.
Larry
Stick0413
Hopewell, VA
Larry
And there are others like me that actually like the bigger case that the 500 (and 96, 97, etc.) comes in. Its a toss up with what size to use because you will please some with the bigger size and please some with a smaller size. Both GRE and Uniden have what works for them in their respective scanners.
