PSR 500 Stuck on DSP Loader DSP Boot: F1.1
royalzapper
Hamilton County [Ohio]
"INTERMITTENT PROBLEM"
Turn Unit On
No Welcome Screen
Goes straight to
DSP Loader...
DSP Boot: F1.1
DSP SW Upgrade
Wait for PC/IF
Not sure what is up ??
At times unit turns on with no problem
When unit turns on with Welcome Screen
Press 3 this is the info
Vers - Key Exits
uP Appl VER:F1.8
DSP App VER:F1.4
DSP Voc Ver:F1.0
Prog with Win500 2.0.1 & 2.02
This is my p500 file name "BZ 12 APR 2011 CK CC.p500"
Extended Settings ALL set to Default
1st time I seen this Display was after upload to Scanner
This is a Intermittent problem
I have changed the p500 file name is see if this helps
royalzapper
royalzapper
GLOB EEPROM area
initialized to
defaults.
Press any key.
Press key then I get this display
DSP Loader...
DSP Boot: F1.1
DSP SW Upgrade
Wait for PC/IF
Factory Init
Erase Memory
ENTER if APPROVE
CLEAR to EXIT
Cleared Memory & Cleared ALL V-Scanner
Turned off then on I get this display
DSP Loader...
DSP Boot: F1.1
DSP SW Upgrade
Wait for PC/IF
re-installed
DSPUpdater_PSR-500-600_U1.4.exe
CPUUpdater_PSR-500-600-BootF14_U1.8.exe
Still have problem Intermittent when I get it to turn on
with Welcome Screen scanner works
Need to return it ?? Only 2 weeks old.
Lucky me
royalzapper
http://forums.radioreference.com/radio-shack-scanners/18067-closed-mode-mot-bleed-over.html
royalzapper
Stuck button?
No
You need to press 3 button in sequence
"While the "Welcome" message is displayed, press 0 PGM ENTER (in sequence).
This will place the scanner in its DSP update mode."
Turn Unit On "No Welcome Screen" Goes straight to
DSP Loader...
DSP Boot: F1.1
DSP SW Upgrade
Wait for PC/IF
When you turn unit on Display
DSP Loader...
DSP Boot: F1.1
Then will Displays
Welcome Screen
Unit will work !!
I have to keep turning the unit on & off
About 80% of the time will go to
DSP SW Upgrade
Wait for PC/IF
royalzapper
royalzapper
Update
Thank you all for your Reply's
Returned unit today
Got to R&L Electronics
Was like when you go to the Doc and all your pains goes away.
At the store the scanner was working with no problems
Turn unit on then off
DSP Loader...
DSP Boot: F1.1
Welcome Screen
And the unit worked every time !!
We did this for around 15 mins........
"Scanner is working we do not see ANY problem
have to see a problem before we will replace it"
THEM we tried it one more time..... Boom there it is !!!
DSP Loader...
DSP Boot: F1.1
DSP SW Upgrade
Wait for PC/IF
They replaced the unit
So now I have a new Scanner (Hope with no problems)
Thanks to the Guys
At R&L Electronics
R&L Electronics 800-221-7735
royalzapper
